Hey Everyone,
I'm working on an airport project at the moment, and am trying to work out the interior lighting. The image below was rendered with only a VraySun, and uses the physical camera. There are light posts visible in the image that run from the foreground to the background with 4 Vraylights each. Each light is using Radiant Power as the lighting units and has a strength of 80 units (Watts).
In the image below, the lights have been turned off for the sake of render speed, and the lighting is coming entirely from the vraysun is being dispersed by the roof membrane material. As you can see by the framestamp, it renders in 1.5 minutes. The issue comes when I turn on the lights in the lightposts; the rendertime suddenly shoots up to 53 minutes!
So I'm wondering what I can do to get that time down (need to produce an animation ultimately). The important points I need to consider are that the roof membrane is semi translucent, and that the animation will travel from outside the building to inside the building.
The image:
Thanks for your ideas,
Andrew
The image:
Andrew
