Little Tudor thing I am working on right now....Still in the beginnings but it is getting there. I really need a crushed bluestone pattern for the driveway....And some packasandrias....spelling?
Also...I want to add reflection in the windows. How do I add that plane thing and have the material reflect on the glass? Also..any suggestions are helpful
Hi eric , use the vray override reflection and place the bitmap that you want to be reflected there.
you can drag instance it into the environment slot and then adjust it by checking use environment background on the vieport background screen (Alt + b).
after you finish adjusting it you can replace the environmet map with sky you have on your image and leave the vray override reflection with the new adjusted map.
Howdy Eric. It is good to see you here and over at the Autodesk forum. I posted a response over at the Autodesk forum, but basically it was to check this thread out:
