WIP: Development Aerial
  • #16
    ZDepth
    ZBuffer or actually ZDepth map is rendered out of Max through Vray Render Elements. It's basically a B&W depth map; what's close is white and further away is black. Then just load into AE and use as it as a mask to display effects put on for fog etc. Does this make sense?
    • #17
      Re: ZDepth
      yep...so, if i may be so bold, what were the effects you used? How did they change the original and why AE and not Combustion?
      mh
      • #18
        Mainly just desaturation and added some whiteness. Basically use AE just like Photoshop, except it's for animations not stills. Don't have or know Combustion so AE it is!
        • #19
          Very nice! Great outdoor-morning feeling.
          Your tree-approach sounds very interesting. But if a tree model uses leafs with alpha-maps, how can you "convert" them to non-alpha then? Or do you simple just kill the alpha, so that every leaf get the shape of a plane?
          • #20
            I'm not exactly sold on the Z-Depth treatment. It seems more like a soft focus for some reason and it makes it look like a miniature. I think it may be the fact the the atmospheric should be more in world Z instead of camera Z. Otherwise, it looks cool. Trees and ground are well done. The rooftops may be a bit bright and the water too blue and perfect.
            • #21
              I have been creating a library of 3d trees as i need them. I take Onyx trees that have the right tree structure but wrong leaves, convert the trees into mesh, select the leaves only and detach them, make the correct leaves and/or flowers as mesh objects, get the pivot point and angle correct then make a scatter object using the detached leaves as the scatter object. It's been working great so far.
              mh
              • #22
                I agree. the distance effect isnt that good since it does make things look like a model. more than likely you need to desaturate the distance and add in a tiny bit of blue.
                • #23
                  I love the softness of the image!
                  • #24
                    Converting opacity maps to geometry
                    I need to use a large amount of xfrog trees for a scene and could really use that script that you talked about. Is it possible that you could send it to me? Or can I purchase it somewhere? Please advise. Thank you!
                    • #25
                      Viscon Jack, there's no scripting involved, just re-working the models with in Xfrog 3.5.
                      • #26
                        I can't see the image. Does anyone else still see it?
                        • #27
                          nope not anymore
                          • #28
                            Removed!
                            Removed image because it was being posted on other sites as some one else's work Remember your watermarks!!!
                            • #29
                              What?? I really think we need to start a list od these people and at least submit the website so we can spam.
                              Eric Camper
                              Studio 3D
                              www.dbfinc.com/studio3d
                              • #30
                                That is really pathetic!!!
