Bali backyard
very nice.
only one crit from me - have you used a sharpening filter for the AA?
You've got some high range value pixels on the water at the pool edge which are white with black rings around them - try using the Quadratic filter and see if that helps.
Thank you again for the replies!
sv, yes I use catmull-rom, thanks for pointing that out... i didn't notice previously.
dominique, the coconut trees are onyx... I've been looking for someway to add color variation for the leaves (actually, for every onyx trees i have), but still can't find a quick way to do that other than manually selecting each leaf and assigning different mtl... or do i miss something? This one may really help me in the future
as about the design, it's not mine... I think it's some kind of a mix of modern-traditional
cheers
HarryHarry G
i don't really know about that, but i guessed you are using onyx right? onyx can do this. afaik, onyx is capable of randomly applying several IDs to the tree's canopy (the leaves). like they have this color green to yellow, green leaf and yellow has different material id. and sometimes in between green and yellow , so 3 ids.
here's example. (ofcourse my material suck big time, but that's not the point) just to show different color
Dominique Laksmana
