Product Demonstration Still
  • Product Demonstration Still
    Very quick little project:
    Rendertimes are about 25 mins for a 1280x720 resolution.
    Nothing special in the setup.
    I particularly liked how the 2-sided material worked out on the trailer roof
    Ben Steinert
    pb2ae.com
    i like the 2 sided as well. Don't use it much though for render times.
    ONLY TRUST A COMPUTER YOU CAN THROUGHT OUT A WINDOW
      Render times are long if you use a vraylight behind them. However, I found that using a plane with the vraylight material applied instead of a vraylight will cut the long render times significantly while achieving the same look.
      Nice render, sorry to go off topic.
