still life
  • still life
    hello there
    i thought i'd show another work i did recently.
    these ones rendered really quick despite the use of DOF.
    i don't remember the exact render-times, but i'll render it again just to be sure that it rendered fast.
    greetings
    ale
    ____________________________
    www.indivizuals.ch
    Very nice indeed..........!
      Great... and very nice magazines ! I you want to share those, you're welcome
      Philippe Steels
      Pixelab - Blog - Flickr
        A question regarding the blue wall.............
        Did you use the Vray Override material to control the colour bleeding, and do you use it (like me) for most of your materials now?
        Thanks
          hi guys
          thanks for your words. i really appreciate it!
          for the blue walls: this one does not use the override mat.
          i usally do it with the white walls or the pavement/floor.
          @Pixelab: i could only give the geometry if you like.
          www.indivizuals.ch
            [quote="deneb26"]
            quote]
            I don't understand why the blue wall has not bled onto the white walls if you have not adjusted the GI material slot of the blue wall. Perhaps you can explain for me.
            Thanks
              hi tct
              the texture/color is quite desaturated and again i use the LWF and therefore the textures are loaded with a gamma of 2.2
              here is a downsized sample of the texture used for the blue wall.
              hope i could help you.
              ale
              www.indivizuals.ch
                Ok I think I'm beginning to understand...................
                How do you prepare your textures to be gamma corrected. Is this within Photoshop, and if so how?
                Sorry to be a pain, but it appears I may have missed something fundamental with my LWF setup.
                Thanks again
                  no problem mate.
                  i tend to use desaturated colors from the beginning for texture-creating.
                  the textures are loaded within max with the 2.2 option in the gamma/LUV settings (i think you already have this activated too).
                  so no need to do other convertions outside of max.
                  www.indivizuals.ch
                    I will look into this as I seem to get much more bleeding. I really do appreaciate your help in this.
                    If you don't mind I may keep posting next week as it's beer time now.
                    Have a good weekend!
                      hehe, you're right about beer time.
                      for me it's cinema time this evening.
                      so see you next week. and of course i wish all a relaxing weekend.
                      ale
                      www.indivizuals.ch
                        I am not sure, but it looks like you have a little chromatic abberation - i look at the edges of the wall/ceiling in the dof'ed background.
                        If i am correct, how did you achieve this effect? I like it a lot.
                        Nice renderings - Cheers!
                          hi stupendousman
                          you're right about the chromatic abbe.
                          this effect is done in post with PS.
                          there's a filter in the 'distortion'-filters category; i think it's called 'object-correction' or something.
                          it's used to reduce/eliminate pinching/vignetting/perspective distortion and abbe from fotos.
                          but i missuse actually to add the abbe effect to renderings.
                          hope this helps.
                          edit: thanks ene.xis for the spelling =)
                          ale
                          www.indivizuals.ch
                            lens correction
                            Nuno de Castro
                            www.ene-digital.com
                            nuno@ene-digital.com
                            00351 917593145
                            • #15
                              Thank you so much! How can I have missed it... Have been looking for action scripts or similar to do this for ages. Damn... [/u]
