Help needed - updated
  • Help needed - updated
    Hello everyone,
    This is my first post, I am working on a project of a simple beakout area. But I'm getting a lot of colour bleed from the floor. Is there anything I can do different?
    I using vraysun/sky/camera with reinhard color mapping with a burn value of 0.3. I'm also working in gamma 2.2.
    Thank you in advance.
    Ash
    yes, lower the saturation spinner in your irradiance map controls.
      you could use Vray override material
      http://www.spot3d.com/vray/help/150R...verridemtl.htm
      show me the money!!
        percy & flino: Thank you very much for your advice.
        Both options work really well, I will play around with both settings.
        Thanks again for quick response
        Ash
          the vray override is the bst bet if you have read my tutorial on dark or overly saturated scenes
            Hi guys,
            Here's an updated to my scene. I big thanks to tONy31 for his help with the lighting.
            Please feel free to C&C.
            Ash
              Your ceilings and lights look amazing... Could you please share how they were down....
              Beautiful work
              Arkitec
                Well done Ash...good work. Are you pleased ???
                  Dude you could try and change your window glass mat... i had to do that on your test scene to get the direct sun light in.... try and add a background image as well matey..
                    bring on the next project hey matey !!!!
                      Arkitec - Ceiling is simple boxes with two ceiling grid maps applied. There is a vraylight on top of the drop ceiling pointing up onto main one. Lights were downloaded from ERCO site, with IES files.
                      http://www.erco.com/
                      tONy31 - I will look at glass material. I am very please with result, but I have a way to go to get to your level. I hope to post some new images soon. Thanks again for your help.
                      Ash
                        Nice work. It may be the color scheme but it appears to be a little it too evenly lit in that some surfaces you may expect to be a touch darker since they are in shadowed areas. Very minor thing though imho..
                        A background would help finish it off as mentioned but otherwise looks great
                          Great improvement!
                          www.visumporec.com
                            amazing progression from the first image to the final.
                            looks great! nice wall graphic.
                              very good looking rpc's....
