70' tall trees with 2' long leaves...interesting. If you want thr trres to be more realistic. Seperate the leaves from the trees, make a realistic leaf/leaves and use the old leaves as a distribution object, then delete the old leaves.
mh
My suggestion was to open your trees (Onyx, right?) in the modeler, and make the tree height it is going to be in the model. This way, the leaves are the correct size for the tree. Or, at least go into the modeler, and select miniature leaves. That way, when you scale up, they don't get as large.
