i think the blueness of the water is actually spot on - if you look at some marketing brochures or photos of holiday homes the pool water is always insanely blue.
I think your balance of warm lights and the nightsky is just spot on.
Do you use the VRay Physical camera for these scenes?
If so how do you manage to get your background image to show up so bright (correctly exposed)? When I use the VRay camera by background turn up almost black.
sv: thanks for you nice words ...
Yes the client show me image in one real estate magazin and want this warm feeling between blue and yellow.
I show you one piece of image from magazin (reference color)
olitech: Thanks, yes on the bulb is small glow done in PS
WWX: Yes I allways use vrayphycam with color balance sometimes adjusted with Lele's script and sometimes of mine.
On first image i have one plane that simulate environment and second is done in PS, rendered in .png with alpha channel
Does the color balance feature sort out dark backgrounds? How does this work. Say my scene is correctly exposed except that the background looks black, won't adjusting the color balance to composite for the back ground, effect the rest of the image negatively?
Lele did advice me once to increase the brightness of the background image, but not sure which setting to increase.
