Industrial
  • #16
    Fantastic image and the detail, its painful to think how long this took.
    Very inspiring, I soooo need to do some personal work.
    Death of the industrial age?
    One humble comment would be to make the foreground silo a centre piece and cover it with big-leafed ivy (ivygen) and flowers as a bold contrast to the decaying surrounds? In death there is life - now I'm getting all philososphical.
    Then again it might look shit.
    Brilliant work!
    • #17
      Top notch job Peter!
      Regarding the script used for the flaking paint, without posting it (unless you want to ) could you give an indication of how the script works? Is it a modification of a scatter comand? Possibly using a random selection of 'paint peeling' vray proxies?
      The mind boggles! It's very effective though.
      • #18
        No, is easier. Just select object you want, then run the script. It will create nice topology via polyboost ,then it will break object to element, detach them, set pivots for each of those objects to corners, and ramdomly apply bend modifier with random values from given range
        Noemotion.net - www.noemotion.net
        Peter Sanitra - www.psanitra.com
        Noemotionhdrs.net - www.noemotionhdrs.net
