power pole
  • power pole
    haven't posted anything in awhile. this is from about a year ago and i'm just now able to show it.
    And the reference image...
    www.boxxtech.com
    Pole
    Crazy! What was it for?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      its for a litigation case. the pole was poorly put together and the wires were rubbing together causing sparks to fly everywhere. it started a fire that burned a few hundred thousand acres. i have an animation of the wires rubbing and sparking...i'll see if i can post it.
      -joe
      www.boxxtech.com
        amazing the uses people find for cg these days!
        www.peterguthrie.net
        www.peterguthrie.net/blog/
        www.pg-skies.net/
          Hey that's pretty cool! Especially that toonversion.
          www.vknt.be
            Really, really nice what a bizarre job to get!
            Many Thanks
            Patrick
              thanks for the comments. this is actually a very typical job for us though i admit, the litigation viz business can have some strange subject matter at times.
              -joe
              www.boxxtech.com
                Very cool. But why would the client need a 3d rendering practically identical to a photo?
                "Why can't I build a dirigible with my mind?"
                  well the animation is what they paid for. if you look at the reference image you can see that it is slightly different than the still. the reference image shows the pole after the line snapped. the animation shows the lines rubbing, sparking and snapping...then falling into the position as seen in the reference image.
                  the stills shown above weren't really used by the client...its just the 1st frame of the animation. i'll be able to show the ani when i get around to posting it on our site
                  thanks
                  -joe
                  www.boxxtech.com
                    Ah, I see. I haven't met anyone here doing litigation visualisation. Sounds quite interesting though. Maybe the litigious nature of U.S. jurisprudence requires more of this type of work.
                      I would love to see the animation! You've done a top notch job on matching the model to the reference photo.
                      Dusan Bosnjak
                      http://www.dusanbosnjak.com/
                        yep really great job mathicng the image. thumbs up!
                        Ruben Gil
                        www.spvisionz.com
                        www.linkedin.com/in/s2vgroup
                          Nice Work. So how does the litigation visualization business Pay?
                          Mike Henry
                          http://mhenry.cgsociety.org/gallery/
                            If the animation looks as good as the still, I'd really want to see it.
                            I'd say the reference image is a bit softer, which I think looks better.
                            www.artbyarjan.com - Online portfolio (temporarily offline)
                            @home:
                            / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
                            / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
                            @work:
                            / Intel Core2Quad Q9450 @ 2.66Ghz /
                            Nvidia Quadro FX 3700 / 8Gb Ram /
                            / Vista Bussines x64 /
                            • #15
                              thanks again for the comments.
                              here it is animated: http://www.3dspeedmachine.com/misc/sparks.htm
                              it looks a little different than the still. its been awhile since i worked on this case and i forgot that i had to turn off displacement for the animation. i never did like the look of certian things, like the sparks, but that wasn't up to me.
                              @ drjan: now that you mention it i agree...softer looks better. i recall adding some sharpening to the still in post
                              @ mhenry: i cant complain
                              www.boxxtech.com
