I really like the night shot, even though I'd put some furniture in there, it'd look better than it already does with a bit more detail.
the other images have some dof problem imo, you'd be really hard pressed to get anything blurred behind the subject in such shots. it kind of makes them look unreal, and the last one as if it was much smaller than it's supposed to be.
also chromatic aberration looks a wee bit distracting.
Really nice shots. We're working on a similar house at the moment but I think this one looks alot better.
How did you do the gravel/grid stuff in the last render? Is it modelled?
I agree with rivoli about the furniture. The night shot looks really good, but itd be even better with some furniture in it.
www.artbyarjan.com - Online portfolio (temporarily offline) @home:
/ AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
/ Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu / @work:
/ Intel Core2Quad Q9450 @ 2.66Ghz / Nvidia Quadro FX 3700 / 8Gb Ram / / Vista Bussines x64 /
Looking pretty good. I would consider adding detail and dirt. Maybe joint lines/shadow gaps in the stucco. If you model in the shadow gaps, you could then add vray dirt with inverse normals to "dirty up" the stucco panels.
Also, while your grass looks pretty good, if you used Vray Fur for grass on any shots with grass in the foreground, it would look even better.
Thx guys for you comments,
rivoli: I dont care if looks real or not, the main focus is on the arhitecture
DrJan: gravel is simple grid with displacement
Its the color fringe at the edges of objects you get with certain cameras or lenses, often something darker against something brighter, such as tree against sky, or at the edges of a wide-angle lens.
don't know if anyone really needs it, being the side effect of cheap lenses. as long as doing it goes, you can either shifting the image's channels slightly, or use the lens correction filter.
Ah I can see it now, it appears as a green or purple edge in a couple of them. Whats the purpose of this effect? (no slight on your images intended ive just not used this before)
I guess its to make it look like an amateur photo, which in theory might be considered more realistic. I see a lot of bad camera phone photos of buildings around our office...
@ visumporec: How did you do the aberration? In Camera Raw, or a photoshop script?
The only truly realistic 'amateur style' 3d image ive seen was that famous Maxwell flashbulb render knocking about awhile ago. But as he said its about the architecture.
