Black Duck
  • Black Duck
    Lots of work, but lacking in quality. What will help?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It's not lacking much in IMO - very nice work on the modeling and texturing, I think it's just lighting/compositional stuff that could move it up a notch.
    I would suggest opening up the shadows on the grass a bit and changing the time of day. The lighting at midday looks very flat and unflattering for most things. I might try moving the white car too. Not sure where, could just need to tone down a bit (drawing the eye quite a bit right now). I might also shift the second car from the right so it's not tangent to the last car, or so that it is more so but where it is has an odd tension.
    Just my .02
    b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
      Post
      Thanks. I put the white car for some contrast since that area is the main entrance. I tried the sun 45 degrees from the camera, but moved. I'll play with that.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Headlights on right most car are blown out and take away from the image a bit. I think the most outstanding issue is the roof lacks definition - it's hard to tell what's in shadow and what's not, needs more shading or something.
          too much contrast imo, id raise the gamma a bit and compensate with the camera settings. (just a little)
          WerT
          www.dvstudios.com.au
            The shadows are vary dark too.
              Ok, the cars aren't problem here. In fact I think the cars are fine other than the blown-out headlights.
              The problem is just overall composition of the rendering. First, the cropping of your view needs to change. The subject of your rendering is the building, but it occupies such a narrow strip of the total render. There's way to much sky and grass.
              So, here's how you fix it. Recrop the image like the attachment I'm showing and there will be much more emphasis on the building. Notice that this crops out the shadows on the grass. This actually is a nice feature, so I've painted in an example of where the shadows should be in the recropped version.
              Also, you should add some foreground framing vegetation on the edges of the image like I've painted in green. This will give the visual clue as to where the shadows are coming from, even if it doesn't match the shadows. It will give the feel of looking through trees and give a sense of depth of a world existing to the sides and behind the camera.
              Third, the trees up against the building look weak and just planted. Get something bigger in there, even if it takes some photoshop work to do it. Your background trees are much better.
                I tend to agree with Dynedain.
                Your houses are in the midddle and composition looks "undecided" between grass and sky. Try cutting halfway through either sky or grass (you decide what is more inportant)
                Rendering itself looks good
                zoran
                  Yep - needs a lift in the shadows, there's no detail under the eaves of the roof and that'd never happen in real life - bit more gi bouncing or lwf methinks.
                    Either do some heavy painting/photoshop cutout work in the foreground, or try to add some 3d to it, or just crop it.
                    It's a rather simple problem that's not necessarily 3d related. You have an image, an illustration, and a specific composition. The subject of your illustration is in the background, while you are showing a rather uniform and boring element in the foreground and midground.
                    You have somewhat solved the foreground with the shadow, but it's still a large portion of the image that is very uniform.
                    Think along the line of kids playing soccer on the lawn somewhere in the line with that flock of birds.
                    The only problem with this is that it would probably take as much time to set up as it did to model the complex
                    But then again, if you were painting with watercolors, you would surely splash something in there to simulate something like this. Soccer, flowers, shadows, kids flying kites and stuff...
                    my 37 cents.
                    Dusan Bosnjak
                    http://www.dusanbosnjak.com/
                      Black Duck
                      I wasn't really talking about composition I guess. I usually use the 1/3 - 2/3 rule, but that is done in post. I sent this one to render and I'll post it later today. Everything everyone mentioned I think I have already addressed. Thanks for all the comments and suggestions.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Here is the final. The architecture is boring, but I tried to create some interest.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Reflection
                          Several time I have heard I should add a Fresnel reflection to everything. Can someone elaborate?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            I think it's better overall, although maybe a touch moody fpr a seniors home A little more brightness in the area of the building might help.
                            Nice job.
                            b
                            Brett Simms
                            • #15
                              Ugh! the color adjustments make it so dark and foreboding! Especially for a retirement home. Go back to the original colors and saturation.
