Private Home
  • #46
    Who owns this
    Originally posted by sea2stars View Post
    Just noticed that you can download another version of the plugin off the site from here; that RAR archive is about twice the size of the demo archive.
    I am confused... I paid $50 from the maker of vrayscatter and it doesn't work. This is a totally different site.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #47
      Odd.
      I'm still using the old ancient version on 2008.
      • #48
        gradient edge
        Does it work in 2010?
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #49
          I have 2010 installed but haven't started using it for production yet.
          Nope.. I just copied it over from my 2008 install and it won't initialize; neither will the 2009 version.
          • #50
            gradient edge.
            Bummer. I remember it not working so I bought the new one, which doesn't work for me. Does anybody else have any other solutions for what gradient edge allowed us to do, which was to blend materials together along edges?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #51
              Masks, but they can be time consuming. What is the issue you're having with the plugin?
              You can also try ColorEdge from ItooSoft which is free.
              • #52
                Gradient Edge
                The issue I am having is I am not getting a smooth material transition. The transition is jagged. I contacted their support, but after 3 weeks I haven't had any replies. I looked into the tool from Itoosoft, which by the way answers their support posts, but it works much different. What I used gradient edge for was to soften up the sharp material transition edges like from grass to asphalt.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #53
                  It works different, but with a little work it might meed your needs temporarily.
                  Here's a test scene I just put together using a VrayBlendMtl and the ColorEdge as a mask; hiding any edges I didn't want included. You'll need to download the plugin to take a look at it though.
                  • #54
                    gradient edge
                    I'll check it out, thanks.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #55
                      Gradient Edge
                      Thanks for the share and it looks great. Now I remember why I didn't use itooosft's plug-in. It works until you a displacement on the grass part.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #56
                        You the whole thing?
                        3D displacement should work.
                        • #57
                          Another quick and dirty test. 3D displacement with a displacement map masked using ColorEdge.
                          There's a seam on the smaller sphere where the two meshes interface, but I'm guessing that's due to the low number of segments.
                          • #58
                            Displacement
                            Can you post that second file? All i am getting is the displacement around the edge of the plane.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #59
                              gradient edge
                              I guess I can copy my road plane over itself and raise the second one a tad. I can apply the color edge to the top and make it, in this case, lighter. The darker bottom plane with show through on the edges.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #60
                                Ahh.. I didn't modify the original meshes at all. Let me create a file with a flat and warped plane? I'll have to change the displacement texture to a noise map though.
