render problems
  • render problems
    hello,
    i'm having problems with this scene. when i render it on my local machine it renders fine. when i send it out for network rendering it gets some odd looking shadows on the plane and on the ground near the plane. any ideas?
    thanks
    -joe
    rendered on local machine:
    rendered on network:
    www.boxxtech.com
    usually something like this is a result of one machine not seeing a texture, however i dont see any bucket sized errors so... weird.
    WerT
    www.dvstudios.com.au
      how are you computing your gi?
      does the problem still exists if you have gi turned off? if no, then you are probably not setting up your gi maps correctly.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
