Perfume ad.
  • Perfume ad.
    Here's a render done with Realflow, Max and Vray. Its for a perfume print ad (no client, just portfolio stuff) and the blue 'bottle' will be replaced with photography by the retoucher.
    The render is a whopping 7000 pixels in the longest dimension and rendered in 23 minutes!
    We shot the perfume in-house and then did a 'silver ball' HDRI.
    Comments much appreciated, Ive got time on my hands to make changes!
    Thanks, Tom
    http://1.bp.blogspot.com/_0GCIc31NK6..._001_small.jpg.
    Tom Livings.
    INFXstudio.com/
    And this is the render with the photo-composite.
    http://4.bp.blogspot.com/_0GCIc31NK6...e_01_small.jpg
    Tom Livings.
    INFXstudio.com/
      Overall it looks very good, but I think the Realflow mesh could use a bit more refinement. It is hard to get around it, but it still has a bit of a bubbly look - maybe tweaking the mesh parameters can give you something that is just a bit more natural?
      b
      Brett Simms
      www.heavyartillery.com
      e: brett@heavyartillery.com
        Thanks ret, I agree, but Im using the demo version which has a couple of limitations. I can only let it calculate on 2 cores for 10 minutes. Im a novice with Realflow, so any practical advice you could give to overcome the 'bubbliness' would be very welcome.
        Tom Livings.
        INFXstudio.com/
          It is always hard to do - RF just does not allow for any good universal settings so you have to play. I would suggest that you try just turning on the filtering for the mesh and see what that does for you. I do not have RF with me right now so I cannot look up the proper names and I cannot remember offhand, but the two values for the mesh that are set per emitter (radius and the 'attraction' value between particles - name totally escapes me) usually need to be adapted along with the filtering. It becomes a bit of back and forth between the filtering values and these two. The other one that can make a difference is the polygon size - if you don't have enough poly's the shape will be much chunkier no matter what you do (maybe obvious, but it took me a bit to figure that out )
          I really recommend the Gnomon RF training video as well. It's not very exciting to watch, but it does give a really good overview of the tools.
          b
          Brett Simms
            Thanks Brett. Ive just ordered the Gnomon RF training.
            I had a look at your site. You have some lovely work in there.
            Tom Livings.
            INFXstudio.com/
              thanks Tom!
              Brett Simms
                very nice.... you need to post more...
                www.rnrassociates.com
                  well thankyou Leo, I shall do.
                  Tom Livings.
                  INFXstudio.com/
