Staircase
  • Staircase
    Since I changed jobs recently and can't show any work I've done for my previous employer in my portfolio, I had to start making some own work.
    I took a picture from a magazine and tried to replicate it. I'd like some opinions on things I could do to make it look better.
    www.artbyarjan.com - Online portfolio (temporarily offline)
    @home:
    / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
    / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
    @work:
    / Intel Core2Quad Q9450 @ 2.66Ghz /
    Nvidia Quadro FX 3700 / 8Gb Ram /
    / Vista Bussines x64 /
    I would say that there is a lack in contrast, (but as I can not refer to the original)
    Good number of stairs. Seems like a lot. Was the hinges spacing like that in the original picture?
    Alain Blanchette
    www.pixistudio.com
      The amount of stairs is the same as in the image (less even). What I did is take the average height of a floor (3m) and divide that through the maximum height of a step (18,5cm) which results in 16 steps. I used one more...
      With hinges you mean on the door? In the original image, the hinges aren't visible, but I modelled that door for another project and decided to use it again. I used a door in our office as a reference (it was 2.7m high).
      @home:
      @work:
        nice render
        The exterior seems very strong compared to the interior. Cant tell without seeing the photo how close it is to reference but usually if you take a photo inside looking out the exterior is very blown out if not completely white.
        like thablanch said some more contrast would help and the stairs mat looks a bit flat could do
        with some more something, not sure what.
        really like the shadows falling through the stairs onto the wall, might be nice to do a cam from an angle close to that wall looking up through the stairs or down near the water.
          I think you have a great start to this image. I also agree that there is lack of contrast. I would adjust all of the materials to give a little more spark to the image. Maybe do some volume light affect from the window (like this: http://www.evermotion.org/index.php?...fold=exclusive).
          Jeremy Driskell
          Reflective Rendering
          www.reflectiverendering.com
            By hinges, I mean the spacing between them, the 2 one from the top are closer together than the other ones. Could be the design.. it is a question.. but more design related than image related..
            Alain Blanchette
            www.pixistudio.com
              @pg1:
              That's a nice suggestion. I'll see if I can make another shot from this scene.
              @drisk:
              The contrast remark has been made a few times now, so I'll go and look into it. And thanks for the volume light suggestion.
              @thablanch:
              I haven't exactly used standard distances, but it happens with high doors, that there are two hinges at the top of the door to stabilize it (I've worked for a contractor as a part-time job during high-school). It could be that the spacing should be a bit different though.
              @home:
              @work:
                Very nice, but i think there's a severe lack of cowbell.
                  Har-har
                  @home:
                  @work:
                    I think it needs more detail.
                    Set V-Ray class properties en masse with the VMC script
                    Follow me for script updates: @ollyspolys
                      In what way? And which elements need more detail?
                      I appreciate your comment, but I have no idea what you're aiming at at the moment...
                      @home:
                      @work:
