A couple of hastly done interiors
  • A couple of hastly done interiors
    Day and a halfs work. Some sort of a church center, existing space being remodeled.
    I modeled everything except the table (evermotion) and the cooktop (.dwg block).
    Before you ask about the position of the TV, it's a donation and it probably won't be used very often.
    Dusan Bosnjak
    http://www.dusanbosnjak.com/
    Nice
    I like the lighting and especially first and second images, good work...
      I used some fill lights in the kitchen but what i really wanted to do is use some artificial lighting in there. But since i had no info about the fixtures or anything, i decided not to. Thats why the back may seem a bit dark.
      Dusan Bosnjak
        Good work and nice lighting If You add some more stuff to kitchen and living room will be real
        Freelancer
        http://<span style="font-size:8px">w...dio.com</span>
          Looks nice. I think the light levels are very realistic, though I wouldn't be surprised if your client asked you to brighten it up a tad in the corners. Like HCPiter says, a bit more detail would complete the images nicely. Good work!
          John Pruden
          Digital-X
          www.digitalxmodels.com
          3D Model Marketplace
            Nice work. Lighting looks good. The door handles seem a little strange to me (pointing down).
            Mike Henry
            http://mhenry.cgsociety.org/gallery/
              The door in the back of the kitchen is a slide door, i thought this would make more sense and no one complained
              Dusan Bosnjak
                I worked a bit on the sofa, i'll see if it helps the above images.
                Dusan Bosnjak
