Interpolated Glossy Reflections Test.
  • Interpolated Glossy Reflections Test.
    Just made a quick test with interpolated glossy reflections.
    http://www.suurland-media.com/animat...eflections.wmv (1mb, windows media 9)
    The GI is precalced using every 20th frame, which wasn't enough or I should have made the FOV larger for the precalc, atleast there is some errors in the rim of the image.
    Rendertime started at 2min per frame and decrease to around 1min per frame. Using a dual AMD2000
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
    Nice!!!
    Torgeir Holm | www.netronfilm.com
      I can't play the file, and can't find a right codec. Any ideas on how to solve this?
      regards,
      flipside
      <edit> ok it works now, I played it with the wrong player I think....
      hey thomas did you ran from the fr boards?
        You need media player 9
        Render times are nice, reflections a tad murky, I will be glad to see wood floors that are not mirrors
        Eric Boer
        Dev
          very nice! i wonder it most be take a long time to render
            Eric Boer
            Dev
              r u using glossy reflection from vray mtl?
                Very nice test Suurland!
                Restoeboemi, with those render times? Of course he must be using VrayMlt.
                Gonçalo
                  I still dont get it.. how do you make interpolated glossy reflections¿ I can't find a way to do anything but sloooow glossy reflections Tutorial?!
                    Turn on the "Use interpolation" checkbox right below the Glossy value in the material.
                      Don't have that.. not on the VrayMtl nor the VRayMap (used in the reflection slot). Where is it¿
                        Material editor=> VRayMtl=>basic parameters and Reflect Interpolation
                        Architecture & design Sàrl
                        global solution for architecture
                        www.architecture-design.ch
                          Vince: that is in the old version. In the new version it is right below the reflect subdivs.
                          Bratwurst: which VRay version are you using? Make sure you have the latest version.
                            hello egz,
                            ok, i know "it is right below the reflect subdivs" but the settings are in the panel Reflect Interpolation. (Material editor=> VRayMtl=>basic parameters(right below the reflect subdivs) and Reflect Interpolation
                            Thanks for your precisions
                            have a good day
                            Vince
                            • #15
                              well, he was looking for the checkbox, not the settings
