Fernblick_View
  • Fernblick_View
    Hello,
    A recent priavte work...because i have "too much freetime".
    hope you like it!
    Best Regards from Vienna
    http://www.sehorst.com
    The rug is looking very Flat....did you have it turned on when you computed GI??
      I agree with about the rug, also needs a lot more strands.
      The background image is really nice though, personal photo?
      Are you using vrayies lights? If so, another little tweak you might consider is moving them down about 500mm so the web doesn't cast that spot of light around the downlights...
      Hope that helps,
      Olly
      Set V-Ray class properties en masse with the VMC script
      Follow me for script updates: @ollyspolys
        Re
        Yes the rug has GI--yes more strands could be a solution.
        i know the lights are not 100% realistic..i oversuscribed them a little bit for the look...(yes Vray IES)
