Accord new render
  • Accord new render
    Hi guys,
    I decided to use one of the hdri-location hdri's and backplate. Hope you like the new render. Great set of hdri's by the way !
    Regards
    Steve
    My Portfolio
    Pretty smart looking! Did you model the car or is it an off-the-shelf product?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      Cheers. The car was from a previous project where I used CAD data.
      Regards
      Steve
      My Portfolio
        the car looks good but the depth of field is wrong. looks like you did it in post.
        my bloggy thing - http://www.gav3d.blogspot.com
          I did do it in post. Not sure what you mean by wrong ?
          Regards
          Steve
          My Portfolio
            I see what you mean now. Not sure why I missed a glaringly obvious error....
            Heres an updated version.
            Regards
            Steve
            My Portfolio
              much, much better without DOF!
                phew, much better! didn't wan't to say anything
                www.peterguthrie.net
                www.peterguthrie.net/blog/
                www.pg-skies.net/
                  Dark
                  Great job!
                  One comment, the side doors is very dark, does not seem real.
                  Congratulations!
                    I'd rather you said something..that way I can learn
                    Regards
                    Steve
                    My Portfolio
                      Originally posted by exagero View Post
                      Great job!
                      Congratulations!
                      I used a HDRI to light the whole scene. Im wondering if the plane I set the car on is possibly affecting the reflection back onto the car...It should be just reflecting the road back from the HDRI I thought..if you set the vray plane to alpha cont-1 and select matt object ?!
                      Regards
                      Steve
                      My Portfolio
                        You must disable "visible in reflections" in object properties (vray)
                        A trick I do is to apply a vraymaterial w/HDRI as diffuse map to the matte ground plane - that also solves the problem
                        http://www.flickr.com/photos/norwiz/
                        http://www.fuglefjellet.no/
                          Hi Steve.. thanks for buying the location
                          Without DOF it's for sure a lot better, and does look like you have an object under the car that is reflecting in the car which it shouldn't, getting a more interesting reflection on the side should be possible.
                          Also I think you should work on the windows, they stand out a little bit too bright and like they are milky white, I would make them darker and maybe tint them green a little bit and then lower the reflections. And the b-pillar is bright grey, I assume it has to be black. And the rims could need some markings on the side.
                          Hope you are going to do some more angles
                          /Thomas
                          www.suurland.com
                          www.cg-source.com
                          www.hdri-locations.com
                            Cheers for the comments. I will definately come back to this soon and try out some different angles. Yeah, really impressed with this forest pack...I like the forest shots just on their own
                            Regards
                            Steve
                            My Portfolio
                            • #15
                              I tell you what would be a nice addition to the packs...if you provided a max scene with a vray camera already setup ready for each backplate..just an idea
                              Regards
                              Steve
                              My Portfolio
