In the style of Waro Kishi (animation)
  • In the style of Waro Kishi (animation)
    Hi guys,
    I had to build an animation-ready environment recently in the style of said architect.
    I had to cut a looooot of corners in order to keep render times below 10 minutes per frame in HD on a single machine.
    Having done this, I thought I'd throw in a couple of recent furniture models and drive a camera through it.
    No funky video editing and no soundtrack either. Just a few short sequences stuck together. The compression is not great but it's still probably worth watching it in HD.
    http://vimeo.com/9682327
    Also uploading a few stills (I take no credit for the car model, which came free with this month's issue of 3DWorld):
    Check my blog
    The animation looks really nice - beautiful rendering! The ease in/ease out on the camera movement (end shot#1 to beginning shot#2) breaks the fluid motion in my opinion.
    Excellent work!
    http://www.flickr.com/photos/norwiz/
    http://www.fuglefjellet.no/
      They look great. I especially like the last image. How did you managed to keep the rendertimes under 10 minutes in HD?
      www.short-cuts.de
        Thanks a lot guys.
        Valo: The kind words mean a lot to me. I've long been an admirer of your work.
        Olli: Thanks a lot. I did a lot of trial and error. In the end, I had to accept a certain level of noise, much more than I would find acceptable in a still image. One thing I did was to bring down DMC subdivs all the way down to something like 4 and up the subdivs of the specific llights and glossy mats that were causing me the most trouble. I also kept the intensity of my lights low and raised the exposure in post (I rendered to .exr sequences). Finally I dropped the motion blur and the DOF and did both in post. That pretty much did it.
        Check my blog
          Wow, that was great! No crits from me, and it was a pleasure to watch. How did you light the scene?
            Thanks Voltron. The setup varies slightly from sequence to sequence, but generally with a Vray Dome Light using a VrayHDR map and a sun on top of it.
            Hope you guys don't mind me using this opportunity to plug my revamped website (basically a very young blog with only two posts at the time of writing).
            Check my blog
              Nice start for your blog.
              So, you have a dome light and a V-Ray Sun?
              The lighting looks so good.
              Best regards
                Great lighting, and cameras, and post!
                Amazing to get an HD frame in under 10 mins.
                  Nice work, the animation looks great!
                    It is a great work. Very nicely done.
                    Did you use Zbrush for modeling the seating in the last image?
                    for my blog and tutorials:
                    www.alfasmyrna.com
                      Thanks a lot, guys.
                      Pixela: Yes, the Togo seat was modelled in Max and finished in ZBrush. I used the decimation master plugin to bring the polycount from a couple million down to 100,000 polys.
                      Check my blog
