Tilt View
  • Tilt View
    I told you I don't get past the gray scale images; I might as well have some fun with them.
Name:	kitchen 1 (web).jpg
Name:	kitchen 2 (web).jpg
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Bobby... Was this done in Revit... Should I make the switch.
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
      No. It wasn't done in Revit and yes you should make the switch
      Actually the model was done in Revit, but I used VRay for the dirt pass and PS for the Tilt Shift effect.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        i dont get it...what do you mean by tilt shift effect?
        Martin
        http://www.pixelbox.cz
          tilt / shift is a particular type of camera lens that architects use where you can rotate (tilt) the front element of the lens and also shift it up or down - they mainly use it to shoot buildings. On most camera lenses the lines of the building would converge in and it'd give the impression of the building falling away or leaning over - the tilt shit lens allows you to adjust this so that the lines of the building are perfectly vertical in the final shot. The other side effect of this though is if you shoot something with shallow focus / dof it normally makes objects in front and behind of the object you're focussed on blurry. With a tilt / shift lens you can change this effect so that the blurring is more top / bottom or left / right. The top / bottom one gives the effect of something being miniature since that what happens if you're focussed on something really close to you. Here's a gorgeous use of it filmed with a stills camera and a tilt / shift lens. http://www.vimeo.com/3156959
            thanks for explanation! that movie is so cool!
            Martin
              Nice. The effect is simple but really makes for some cool images.
              Brett Simms
              www.heavyartillery.com
              e: brett@heavyartillery.com
                The effect is much better with really saturated colors. the intent is to make it look like a toy.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  The effect makes a typical scene look like a miniature scene.
                    Nice images. Isnt the effect similar to just having an orthographic image with an added bit of perspective or by using a long telephoto lens, standing a long distance from the subject and then zooming right in ?
                    Regards
                    Steve
                    My Portfolio
                      Yep Steve, it's just really hard to do at a huge scale - really dramatic differences in focus mainly happen up close - to get the same effect on an object far away is quite hard - for example it's hard to have a wall 50ft away sharp and a wall 52 feet away totally out of focus in the same shot. It's all down to the way the rays of light converge into the lens - the further away something is the more parallel the light rays will travel into the lens so you'll get less difference between the two walls. The Tilt shift lens comes in really handy for this since you can totally skew the plane the camera is trying to focus on and manipulate what's in and out of focus. Bloody pricey lenses though.
                        Cheers for the explanation. I read ages ago that arch photographers use the tilt shift lens or attachment to sort out the verticals. I love the toy effect though. Its strange (in my mind) that a visual effect or alteration can change the perception of an image.
                        Regards
                        Steve
                        My Portfolio
                          nice renderings, good presentation for a terrible kitchen design
                          show me the money!!
