Thanks for the quick reply! Definatly no throttling going on though, while rendering it's at a steady 1130Mhz all the way through, temperatures stabilize around 77 to 82 degrees which is the normal operating temperature for the Titan X (the fan will only start serious work when it goes over 83 degrees, a function meant to keep the card silent while gaming.)
Will try to see if there are any differences while rendering it from another workstation using DR, otherwise I'll just wait for a new node with just 2 TitanX's to try again and see if it's the different GPU families causing the trouble.
