NVIDIA have two dirver modes in Windows - WDDM and TCC. WDDM means "windows display driver mode", TCC "tesla compute cluster".
TCC works for many non-tesla GPUs as well.
Basically what it does is turning off the video output capabilities of the GPU and making it compute only device. It helps if you don't see your GPUs in remote desktop when they don't have monitors attached, for example.
There are some claims that TCC can also provide faster computing. My tests so far are showing no change in the performance.
When in TCC, many performance monitor tools do not work, so you will have to find a way around that (I did simple console one for this case at home ...).
Blago is absolutely right, and great explanation. I did TCC mode with a Titan X, no increase in performance. But because you cannot use monitoring software and fan control software with it I ended up burning out the card. I think there are less advantages than negatives.
I've never used it before. but i was thinking it may have improved it.
should i plug a 2nd monitor into the other card to get it to run faster?
Something doesn't sound right, you don't need to plug anything into the other card it should be running 100% also. What does the monitoring say on each card for usage?
Are both cards the exact same, I mean same model of the 1080s?
Sounds like the card isn't boosting. Do you have the latest drivers? I remember something about a driver issue not making the 1080 boost. But the other card is so very confusing.
