Hello guys,
I need your help for "scripting".
Gear1 is rotating on z axis (both sides), Gear2 is linked to G1, but only in positive (or negative, I don't remember).
I want to assign a controller on gear2.Z Rotation (cript or expression), something like that :
if G1.Z Rotation=positive then G2.Z Rotation=G1.Z Rotation else 0
or
if G1.Z Rotation=negative then G2.Z Rotation=G1.Z Rotation else 0
I need to setup a 80 moving parts watch, so I need to use "Assign Controller" function.
hope you can help, and hope to be clear...
Best regards.
PS: I will post the same Message on CG Talk... best regards...
or
Best regards.
