Interior views
  • Interior views
    Some interior views.
    Kindly give c&c
    thanks
    Good stuff overall. Please take these crits kindly:
    1) One glaring problem (pun intended) is the caustic refraction around the aquarium. It's drawing too much attention away from the rest of the rendering. Effects like this should be very subtle, I would take it out entirely in these images.
    2) The head statue should be swapped for something else in one of the spaces.
    3) The swastika in the art stands out very clearly. If this is for a condo advertisement, or something similar that will be seen by a lot of people, I would consider changing that to something that won't be so obvious. Is that a custom art piece? It may not even be a problem, depending on what your client has asked for.
    4) The tiling in some of the textures is too obvious, especially on the wood materials. Try using a checker map for the floor tiles. Use it inside of a tiles map and turn/scale one of the textures in the checker map so that the floor doesn't look like one gigantic slab of stone. Or make a custom map in photoshop that does the same thing.
      Thank u soo much
