Hi !
the bottles looks too big, the glass looks too small, the lightning needs a little bit more white, a little bit less blue, color less saturated, especially for green seats. you can blur midmap the wood on ceiling a little. remove the girl maybe.
still a little bit of light splotches to get rid off.
maybe a sticker on each bottle ? some people blurred, 3d, withtransparency at the bar... motion movment of someone in front of the camera ?
more more yellow on the white light on top of the bar.
Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
ok 1 if it is of wines although estan a little great if I agree the problem were that I did them and dimencion the bottle will not try to areglar it the wood of the ceiling this floating does not arrive cables like a the mita that sostines of the ceiling po that happens is that they do not see ademas speaks with an engineer and said to me that they are podian to do asi jajaja if I remain rare the girl will clear it is is my first one to render that I do at night and with that type of iluminacion the one of the chairs floating I do not understand so that I have left asi estan just in the floor and the one of the yellow light not since to do it I do not have left very well if you send the file to setting you can help me to improve JP
No Soy un expertos, ma mi gusto de vere muy bueno imagen.
and Reynaldo, I absolutely didn't understood your babelfish translation. You can write in spanish if you don't know at all english. It still be easier.
Reynaldo non comprender babelfish translator, puedes escrivar nel espanol. Molto Muy Muy bueno.
Jp
JP, today i?ve seen for long time some of your works and if you say you are not an expert its ok, but i think the level of your works is from that category... Saludos desde Argentina!!
Thank you!
it's not difficult with micha tutorials and a fast computer.
'til now, I just have access to one of those two.
que no eres un expertoooooo!!!! eres un ejemplo a segir tus renders son exelentes, bueno tendre que practicar mas esos tutoriales.
fast computer a que te refieres que necesito? me cambio la maquina? mi procesador actual es un AMD X2 4800+ a 2.4Ghz yo creo que resuelve, no hago animaciones
