Plastic tool box
Re: Plastic tool box
I like the smooth reflections and the soft light, but I one problem: your images are allways so dark, the histogram stop at value 220. If I correct the histogram (photoshop Ctrl-L) and set the highest value at 255, than it looks nearly perfect here (first image). I suppose so, your monitor dosn't work like it should. Maybe a calibration tool like the color vision spyder helps.
The lighting could make that the left and the right side of the box (first image) show not the same color and brightness. If you close the eyes a little, you will see no difference, both faces are looking like one and the shape is not best visible. A cold/warm light contrast could be a classical way here.
Also it be nice to give the eyes a main attraction. An arealight above could give a nice attention to the red tool container.
