Cups and other
  • Cups and other
    Here is my last render with VfR. Must say it is great tool.
    - H -
    Re: Cups and other
    Great Render...Must say that I like the water mark on it (is anything real anymore?! ;D)
      Re: Cups and other
      Very nice image.
      ... I only say: www.simulacrum.de ... nothing is real
        Re: Cups and other
        Great image!
        Can you tell how did you get the two mix colors (green and yellow) cups? I think that is using map, isn`t it? How type of map did you use?
        Sorry my english,
        And Thanks
          Re: Cups and other
          artur: it's covered in the manual
          Srecko: great render!
            Re: Cups and other
            Originally posted by arturmf
            ...Can you tell how did you get the two mix colors (green and yellow) cups? I think that is
            As drybarr sad, it is covered in manual. Used gradiant map, fading from black to white, and put it in transparancy of first diffuse layer.
            Ah, I tought that it was original statement
            - H -
              Re: Cups and other
              Well...your leaving the possibility of it being real or CG while Micha is saying that its all CG...a technicality, but I believe it would hold up in court ;D
