it might be better to use a vray Plane for your "ground".
Seems like the pavillon is out in the space.
I think the Granitstone mapping is lot to big- makt the mapping box smaller.
Create a vray sun and increase the sun size-the shadows might look better if they aren not that sharp. The arcitecture is "hard" enough.
The water needs some waves to have more interesting reflection-put a bump map or even an displacemt to the material.
The isometic perspective can be better think about better views.
Ground and roof material is very white you can try some texture or bump.
In my opinion you can handle the render engine- make better materials and views and think about your light- then you on the right way!
