Office Design
  • Office Design
    this is a design for an office block...
    CnC always welcome!
    ...SU6 Pro...VFSU...KT...<br />// Intel Q6600 Core2Quad 2.4Ghz // 3Gb Ram // Geforce 8800 GTX //
    Re: Office Design
    Very impressive. Nice design, careful use of textures and good lighting.
    I wonder if the external views need ramping up a bit as they seem a little dull, but this is very professional work.
    Thanks for sharing it.
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      Re: Office Design
      thanx david.... i studied a lot goin thru urs and others postings here....
      will try to do the exterior next.. that should be a challenge to get right!
        Re: Office Design
        Splendid job Jenu. Looking forward to see more works from you. Regards! -Mike
          Re: Office Design
          The 2nd picture needs lens shift applied on the camera as the environment background texture is shown perfectly vertical yet the model is at a 3 point perspective so the verticals look wrong in comparison.
            Re: Office Design
            excellent indeed Jenu.. the design. I love it.
            Maybe try to play with camera... or encrease the sky multiplier. the images IMHO are still dull. Ive seen the same thing on your Paul russam church interior. Or it might be the effect of your monitor. If its the monitor you have to calibrate it.
            http://www.nomeradona.blogspot.com/
            http://www.sketchupvrayresources.blogspot.com/
            http://www.nomeradonaart.blogspot.com/
              Re: Office Design
              Dzine.... now that i look at those images... (especially the third one) the perspective is all wrong! i added the backgropund later in PS!! will rem that! thank u!
              Nomer.. ur rite! my monitor does need calibration! it looked fine in the system i made these images.... so again i ask.. any good suggestions as to how to calibrate me screen??? :-\
                Re: Office Design
                this is the exterior...
                C+C welcome as always!
                  Re: Office Design
                  A very nice job on the interiors, very subtle and gentle use of textures especially glass.
                  On the other hand exterior needs a bit more work. And i think that everybody should skip the motion blur thingy, especially here you put a displacement map on grass and then blurred it, making it very ireallistic.
                  Keep up the good work.
                    Re: Office Design
                    gligorov...
                    thanks for the comments! i was tryin that DOF thing using the zdepth render.... yea ur rite though.. it does take away the essence of pic! maybe i will reduce it a bit!
                    thanx once again!!!
                    doin exteriors sure is tough!
                      Re: Office Design
                      jenujacob
                      Good start with the exterior shot.
                      I think you need to take care with the scale of the components. The car and also the tree leaves look too big to me. You could also try softening the shadows (try a sun size multiplier of about 3)
                      Good luck
                      David
                      Sketchup 2015
                      Vray version 2.00
                        Re: Office Design
                        I think the car is levitating a bit. Nice exterior though.
                          Re: Office Design
                          yikes! i think there was an electromagnet hovering above that car! thank for finding that mike!
                          david.. thanks for the feedback... will keep those things in mind!
                          thank u all!!
