On the image below you can see a "dressing wall". Take a look at the edges of the door, it looks just nasty, but I don understand why.
I set adaptive subdivision to -1,2 and use catmull rom as a filter.
I also get these weird artifacts above the door and the lighter spot below the wardrobe....??? any suggests?
BWT do you know what causes those white blotches on the left side, inside the wardrobe?
If you want to give it a go....
http://www.volny.cz/mzmeskal/ivo_5_pokus.max
and the mat for the floor....
http://www.volny.cz/mzmeskal/birch_imitate.jpg
Thank you
Martin
Thank you
Martin
