Nice one Mike. Very clean, looks excellent. This one must have taken you some time.
Thanks David! Actually, it's faster than the "kitchenomix I", it took me 2hrs 30 mins on this render. I think it's because of less bumps, displacement, refelections and low poly models or maybe because of the RAM upgrade.
very nice! i like this one much more than the first one! very detailed model i see you like stainless steel like me maybe you could add just a bit more light to the whole scene so you can have a more detailed view of it, and check out the fridge door handles, they take realism from the scene, i like your kitchen mate
Thanks Nektares. I think I'll have to calibrate my laptop monitor, the problem is I don't know how. I think proper lighting is my achilles heel in rendering. Still a recurring problem of mine.
this one is better than the part 1 mike .. my only comments is that your mosaic tiles need some reflection and the wine glass are too high hard to reach i guess?? and the stool chair. look for different models ,if you really like the design of it recreate it mike but make the segments higher bec it still show the edges..
Thanks Jeff! Of course you are one of the people I look up to when it comes to VrayfSu. Yes you are correct, I forgot to put reflective maps on it. With regards to the wine glass holder, again you're correct, I inadvertently moved the hangers higher in the "kitchenomix part 2(scheme 2)", as opposed to "kitchenomix part 2(scheme 1)". I'll probabaly incorporate all of the corrections in my scheme 3.
With regards to the stool, I've already soften/smoothen the coplanars/normals to even 90 degrees already. I think the stool looked jagged and sharp in actual model. I prefer to use this stool because of it's simplicity in design, has wood and metal properties that doesn't grab attention to the overall view. I'll try to follow your advice and look for other models as well that will match the design.
