hello this is one of my first works, im only a weeks using vray, so still learning, c&c welcome.
room
Re: room
Camionero have a good point.The noise from the floor it's from the QMC I belive, but just because you have a poor light. If u like the ambient, use some texture, or bump. Anyway, I still learning myself, so i don't know if my reply help you so much.And sorry for my english!! KEEP UP THE GOOD WORK!!!
Re: room
Your camera needs to be set up so that it "gathers" more light coming in through the wall opening...play with the Film Speed(ISO), F number and Shutter Speed settings...
Also check the Vray Sun settings, size multiplier, etc...
Good lighting is essential, bumps, displacement, etc come later...
keep up the good work
Re: room
thx to all for your coments, helps me to see the things i can improve (wich are a lot, by the way, jeje) ill change setting in vray sun. I have try it almost everything to use the displacement and cant make it work, i have follow instructions in the manual step by step but not good results, i think its me, but im still far away from a good result, will give my best.. stefanq, i have a question, what is that thing of ISO, shutter speed, etc, excuse me if its a stupid question, but im new in this things, also excuse my english...again thx to all..by the way i admire what a lot of you in this forums have achive, you guys are an inspiration to a student like me...
Re: room
Why don't you try to download (visopts) in the download section of ASGVIS. I think Mado has a good interior setting somewhere.
You could also play with the materials to make the color more lively. Also, you can put a big square light(1m x 2m)behind the camera to make it more brighter and adjust the camera settings to 400 iso and 60 shutter speed.
HTH,
Mike
Re: room
hey, mike and stef, i try the camara settings and helps so much, thx, i know the render needs a lot of work but because of you i think the lights looks better and the noise is less, the only thing that i dont like is that some lines or edges look strange, like not straight, but any way thanks a lot ;D
Re: room
well mike i follow the advise of play with camara settings, helps so much, i have to say that something that helps is to be part of a forum like this, you see i dont know many people who render images, they care more of the 2d, and here im learning so much, you know some things dont come with the manual, but im gratefull of the help i have recive... by the way i like your last post ;D
