Been a busy boy...
  • #16
    Re: Been a busy boy...
    haha - perhaps even a footrub.
    • #17
      how did you mix sketchup lines with vray rendering together?
      Scope Design Studio
      • #18
        export line render from sketchup... into photoshop use MULTIPLY as a layer blending styles and scale the image to fit
        • #19
          but how i can render only lines?
          Scope Design Studio
          • #20
            ok! now i understand!!!
            thanks very much!!!
            Scope Design Studio
            • #21
              The best work have ever seen !!!!! how much did they paid to you for all of this !!!! EXELENT
              • #22
                WOW really awsome,you did it with sketchup without lacking your cpu?
                may i know your spec please?
                • #23
                  Just simply amazing. It doesn't look like it was done in SU. Intricate details and superb modeling.
                  • #24
                    Intel Core 2 Quad 2.4 Q6600
                    750MB NVIDIA GeForce 8800 GTX
                    2 Gig RAM DDR3 1300 Mgz
                    and i slaved a machine just like it
                    • #25
                      But how do you get them to match up? The V-Ray render doesn't completely match the SU view...
                      • #26
                        unless u have "overide field of view" ticked in ur camera settings they should be exact...
                        • #27
                          Thats not actually true and its probably the the thing that annoys me most about VfSU.
                          See here for my tests on this matter.
                          http://asgvis.com/index.php?option=c...14490#msg14490
                          • #28
                            So the only way to match them up is to disable the Physical camera?
                            • #29
                              no i used physical camera the whole time... all i can say is that vray is practically perfect (there are a few bugs here and there but they seem to diminish more and more the more u use vray) i had huge problems before with all kinds of things just like ur zoom problem but they melt away after a while...
                              the only tips i can give is:
                              always stick to physical camera!
                              put a 0.75 zoom on the camera (that'll render more than u see on ur screen and u can crop the image urself)
                              its easier to apply 2 point perspective in photoshop
                              untick override focal length...
                              render big change dpi to 150 then resize to smaller image this will give u higher quality images...
                              biebel once told me to tick the overide feature on, then off again (some kind of workaround)... but i havnt had that problem again
                              RENDER RENDER RENDER RENDER RENDER... and a tutorial here and there wouldnt hurt
                              • #30
                                Yea, I didn't want to disable the physical camera. I've had my Zoom to 0.7. Override Focal Length is off, but I think that's off by default.
