still need to learn ps.. c&c are most welcome
just palying with ps....su+vray+cs2
Re: just palying with ps....su+vray+cs2
Jeff
I suggest more transparency for the water to avoid that 'chrome' look. Also have you tried Marc's procedural water material
material > bumpmap > noise > Perlin noise option
(play with the settings and you will get all kinds of water....)
http://asgvis.com/index.php?option=c...16065#msg16065
I like the blurred foreground fern - is this your trademark?
Regards
David
here are some water using only ps.. incase of rush renders....
david i still havent tried the bump water maybe after this project bec. i dont have time to render again... ill study it and post 1 render using that technique soon
and another view (raw render no ps)
regards jds
can you plees make a tutorial how to get the disp. wright on the rooftiles..
Regards,
www.dwanimations.112desgin.orgwww.DWanimations.org | Makes your work come to life
