Various Vray work
Re: Various Vray work
Thank you!! the material is a jpeg from http://www.accustudio.com/exchange/t...hp?dir=textile. The texture is the one at the bottom called whitefabric, hope this works!
Hi Will,this is nice man! Impressive texturing technique you got there!Congratulations!
Do you mind explaining the texturing process of those sofa's, because I try to figure if it's bump there or displacement, but I thought it's better to ask.
Keep up the good work!
Stefan
Stefanq - Thanks for the coments! Ye the sofa is simply a jpeg with bump which i posted earlier. its quite effective i have attached another image to show you. Hope it works for you.
Vodka79 - i have to thank 'David Caudwel' who taught me how to do photomontages, it looks difficult but its actually quite simple once you get the hang of it!! you just simply using photoshop cut out everything in the background where your building will sit, (it took forever to cut around all those tree branches). You will then need to use sketchup photomatch or even judge the perspective by eye, once you have the correct perspective, render the model save it as a JPEG or PNG. import it into photoshop as different layer and slide your image behind the existing photo, and providing you got the right perspective in sketchup it should fit the photo perfectly.
David is probably the best one to explain this because he taught me, but atleast it gives you some idea.
Hope this helps.
There are also some quite useful training videos on u-tube which cover some of the ground in creating photo-matched models
http://www.youtube.com/watch?v=MTFQr...eature=related
David
