kitchen UPDATE!! help with ilumination
  • kitchen UPDATE!! help with ilumination
    hi my last render, your c&c are most welcome
    http://img237.imageshack.us/my.php?i...ocina3aqr5.jpg
    http://img508.imageshack.us/my.php?i...ocina4abx1.jpg
    this renders still need some ps for the outside.
    Re: kitchen
    nice render, but I think its too dark.
    And u must reduce the noise. Did u use QMC? reduce the QMC to 0,0001, it's takes long time but the result quite better.
    Regards,
    Nick
      Re: kitchen
      hi nick i actually used IM and LC i think the problem with the noise is the rectangular light i used 500 on subdivisions, maybe i need to increase it. about if it looks too dark in my monitor looks just fine but would be good if someone else can give his opinion, any way thx bro.
        Re: kitchen
        It's not dark.. I would say that it has the 'teofas ambient' a little bit cold look,
        witch I like by the way. About the noise..0,0001 it will be to much...huge rendering time
        0,005 it' good enough, and for super quality 0,002 if I remember..not shore enough.
        are u using gamma correction?
          Re: kitchen
          here is one with with ps i try to give more life to the scene, but maybe dosent looks good because its hard to incorporate people for me, but ill be gratefull if someone could tell me wich one looks better the one with the men or without him, thx in advance..
          http://img144.imageshack.us/my.php?i...cinero1fk6.jpg
          http://img204.imageshack.us/my.php?i...ocina9adj9.jpg
            Re: kitchen UPDATE!!
            here is an advance of the kitchen and dinning room im working on, i need some advice if its too bright, i mean with ilumination, this is still a wip, lot of details are mising, also materials, but right now ilumination is the isue, need some help here and advice from you guys, thx in advance...
            http://img143.imageshack.us/my.php?i...2800856xw1.jpg
              Re: kitchen UPDATE!! help with illumination
              It's OK bro.
              Tip: if you want the shadows to be softer, increase the sun size,
              I make mine @10, but that depends from scene to scene.
              Also, scale down just a little the floor texture.
              For specific wood object ( in your scene, the table) I found that
              IOR 1.3 and reflection glossiness@ 0.85, give a nice refined look
              for woods, especially the darker ones, reds, browns..
              OK...let's see the final result then..
              Good Luck!
                Re: kitchen UPDATE!! help with ilumination
                Hi stefanq,
                i've sort of lurking around this thread for a while now and i will say that i hav learned a lot from u guys. anyway, i've read a couple of times about adjusting the sun size to soften the shadows. But were exactly can i find the sun icon or tab in sketchup? (or is it inside the vray plugin?)
                Thanks and keep on renderin..
                Joolio
                  Hi Joolio!
                  Here you can find the sun size:
