Vray teapot animation & displacement test
  • Vray teapot animation & displacement test
    Just started using vray and normally post at scf, but I decided i'd post here for a change. my 1st vray animation - watch in high quality
    http://nl.youtube.com/watch?v=lDuVZ3WmMrU
    ps. can anyone give advice on how to embed this video here?
    Re: Vray teapot animation
    nice
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      Thanks 40th. Also applied displacement to the teapot. Took about 25mins to render so too long to animate imo. Here it is :P
        Re: Vray teapot animation & displacement test
        really good renders man!!! but i'm particularly interested in the animation first of all what is the specs of ur computer? and does the new version of v-ray allow to save as a movie file or did u use a different program to combine the frames?
        My name is Lionel.... thanks to asgvis forum http://software.asgvis.com/index.php?option=com_content&amp;view=article&amp; id=792&amp;Itemid=30&nbsp; <br />my first cg contest i&#39;m proud
          Re: Vray teapot animation &amp; displacement test
          Thanks chisel . My computer is a dual core sony vaio with 2gb ram, so not especially fast. The animation was done with the normal version of vray and was saved image by image and then put together in windows movie maker.
          Here is the displacement teapot animated as well, didn't take as long as I thought it would actually:
          http://nl.youtube.com/watch?v=xQWBCS3XtBE
            AS I THOUGHT NEVER THE LESS GREAT WORK! NEVER TRIED TO DO AN ANIMATION OF THAT SIZE BASED ON THE SPECS OF MY MACHINE. YOU'VE INSPIRED ME AGAIN GREAT WORK ;D
              What specs are your machine. I'm sure you can animate too, my main tip is to change your primary render engine to irradiance map and secondary engine qmc. Things will go much faster
                I never get great results with displacement, so I found your teapot simply.... beautiful! The animation it's great as well, but I can't take my eyes of the teapot, even when the image it's not moving. Thanks for sharing with us!
                Regards,
                Stefan
                  Princedragoncok
                  Great work, love the displacement!
                  www.Top3Dstudio.com
                  SU 8
                  VfS 1.48.89
                  Win 7 64-bit
