i really like these, nice feel, the cars are a bit flat for the amount of detail put in but good work none the less what grass/grass-technique did u use?
Yeah you got something going here. The grass is particularly nice (photoshop?) But I would maybe and some diffused reflections on some of your solid colored surfaces, that may help make them not look so flat and this is a bit nit picky but that gray texture on the columns looks tiled...is that the intention? And one other thing...if you are using this for a job, I would consider changing the sky in second one....a little too dramatic. But these are really nice images, keep it up and im sure you will get it perfect.
Freeagent: I will work on cars reflections, I forgot to do the materials on those.nothing special about the grass. what I did was: instead of using the grass greyscale as a bump map I used the carpet greyscale ( arrowway got the flawless texture for carpet) as a bump map..
Steeler: (see ^^^^ for grass comments) the thing on the column was not tiled. Those are common squared semi-perforated wall textures widely used in architectural to minimize sun glare and global heat. I will keep the sky. I like my sky.
torniquetmaster: Yeah love the sky. I agree Its a bit flat.
