vray SSS test
  • vray SSS test
    notes :
    falloff maps and self illumination maps whit output SSS and refracted
    no lights in scene
    THIS IS VRAY????? LOOKS LIKE BRAZIL MORE ARTEFACTS...
      yes is irradiance map whit 7and 20 is just a test the v ray SSS is very slow
      any tips for speed it up?
      the image is like 60/20 irradiance map
        Looks like your using DOF...that tends to slow down the rendering quite a bit. The first image definitely had some DOF. 2nd one looks out of focus. Cool mushrooms though - don't take these with your tea.
          neat!
          Any possibility to get a bit more information on how you
          setup your material? I've been trying to acheive this result by
          playing around a bit, and have not figured out how to mix self
          illum with sss material
          Escher
            YES NO PROBLEM
            vray difuse is a falloff whit an output the output is color blue and is like 16 in RGB the refraction is like .7 and 70% of blackness i hope this helps you =)
              Thank you! Some strange effect, that I don't get any light at all from the material, unless I have a white background color (even if no background is visible)
