Nomeradona Challenge interior
Re: Nomeradona Challenge interior
Originally posted by steelers05Beautiful...the light tone is great and that floor is flawless. Very nice scene nomer....anything out of the ordinary with your settings?
my main thing really is to take care of my materials settings, particularly in increasing the subdivision in their blurry reflections....
Great work Nomer! The floor is perfect, nice touch on the blinds.
Two questions for you:
What was the rendering time?
Why are the corner between the ceiling and the walls are shaded/darker than the rest of the ceiling?
Originally posted by 40thGreat work Nomer! The floor is perfect, nice touch on the blinds.
as for the ceiling. initially that was also my question, so i checked if there as a gap between the ceiling ang the wall. i conclude perhaps the light (sun) source is exactly behind those areas. so they became blind spot. that was my guess though.
i noticed two things Norma, the first is that there is no reflection of the exterior in the floor. is the background image post processed? and two your render time i find is really good is that really the power of the quad core? or is it that there is no glass materials in the window? your reply will help me allot with my work flow. thanx that's a great image.My name is Lionel.... thanks to asgvis forum http://software.asgvis.com/index.php?option=com_content&view=article& id=792&Itemid=30 <br />my first cg contest i'm proud
Originally posted by Chiseli noticed two things Norma, the first is that there is no reflection of the exterior in the floor. is the background image post processed? and two your render time i find is really good is that really the power of the quad core? or is it that there is no glass materials in the window? your reply will help me allot with my work flow. thanx that's a great image.
as for the background, yeah its just an inserted image in photoshop. i saved the render image in png, then if you open it in photoshop, you can insert easily the background.
when you render be sure you should have a save alpha. then after the render output is done you have both the render image and alpha image. if you open your image in photoshop you will see the background is transparent. just create another layer and put it in the bottom of the rendered image. you can just move the image then and match the horizon line with the rendered image.
