my new render (updated)
  • my new render (updated)
    comments most welcome,I have problem which is when i open the sunlight normal rectangle lights not working any advice
    Thanks.
    I just made some changes
    www.jackscabana.co.uk
    Re: my new render
    Nice work, I like it. Only flowers on the window looks unrealistic and maybe you need to try bacground
    http://sketchup.lt/
      Re: my new render
      nice render and design. as simas said it could do without that flower pot on the window. and with sunlight enabled when using physical camera you need to at times increase the multiplier of the vray rectangular light
      My name is Lionel.... thanks to asgvis forum http://software.asgvis.com/index.php?option=com_content&amp;view=article&amp; id=792&amp;Itemid=30&nbsp; <br />my first cg contest i&#39;m proud
        Re: my new render
        could you please explain more clear what is the "need to at times increase the multiplier of the vray rectangular light"
          Re: my new render
          well the thing is that the physical camera most times is used with the vray sky in order to reduce its intensity or controlling it. so the intensity coming from the vray sky is allot more than that of the vray plane light, therefore regulating one (vray sky) will also regulate the vray plane light so in most instances it is necessary to increase the multiplier of the vray plane light. hope that was of some help ;D
            Re: my new render
            nice render!! i love the rug and the plant in center of the table its so amazing how you did it?
              Re: my new render
              Thanks i just download from warehouse in skeetchup and put reflection on the vase thats it.
                Re: my new render
                is the reflection on the vase a vray lnkd material?
                thankyouu
                I can see your faded halo,<br />And I can make it burn again, like the sun.
                  Re: my new render
                  i am using vray sr 1.5.30 its doing itself i dont need to do linked material.Basicly all i do is find this vase in google 3dwarehouse and download it and put reflection layer on it thats it
