apartament krasi
  • apartament krasi
    this projekt is at begining i had alot of work but it is only the first ideas abou that projekt
    what do you think guys pleas c c
    Re: apartament krasi
    First of all, it's good as a beginning, but be sure to improve on some of the following points:
    -The light sources above and near the sofa seem to cast some odd light, try to make some nice shadows into the room
    caused by the sun, put it lower and that should do the trick
    -I don't know if the interior is supposed to be like it's currently state, but as an interior design 'student' I would change
    a few things, especially regarding materials, for example the kitchen tiles/bricks are odd to see in a kitchen,
    except if it's meant to give an 'ancient' or unique mood to the space, but then I would use a displacement map
    for them and not use it so often, only in some particular places, the woods glossiness is spot on! Altough all the different cabinet
    sizes make the whole appeal somewhat 'messed'.
    If I could help you with giving more advice on the design I would be glad to help anyways, then I'll send you a pm with my email adress in it.
    Be sure to keep working on this, it might become very good if you keep on it!
    Greetings
      thanks foxar my friend whant that kind of stones every where and do not want to listen to my advices , i do not like the design of the kitchen as well as you but i do not know how to do plasment of all kitchen gadgets because of that bar.
      the lihts on the sofa is because there are holes on the wall i will fix it
