A nice mill...I think
  • A nice mill...I think
    I'm just modelling a mill but I keep getting errors in the render. See the image. None of the model has any errors (anymore... I had to redo a few things).
    Can anyone tell me where I'm going wrong?
    Zap
    How come Psychics have to ask for your name?
    i had the exact same problem over and over again. tried all the tips and tricks shown in the 1001 tutorials dealing with splotches. those are mainly:
    *get rid of raytrace materials (i used only vray mats)
    *run the cropping script that was written (you can look it up in the tips and trick forum) - didn't help.
    *increasing the GI settings - didn't help either.
    BUT - i found a weird yet effective solution: i noticed that if i save the file, open a previous and less complex version of it (i always keep backups at critical points), render it, and then re-open the funny-acting file - it renders fine (!)
    i have no explentaion, but it does the trick for me...
    hope this helps.
    noam
      erm i think this is a render setting problem:
      you have "photon map" activated in your GI-settings. try "irradience map" instead with "direct computation".
        I HAVE THE SAME PROBLEMS WHEN I USE TECHNICAL CAMERA PLUGIN
          When using technical camara make sure that you uncheck the "max compatiblity shade context" or something like that, under system options in Vray rollout.
          Gonçalo
