Simple Interior Test
Re: Simple Interior Test
Omar very nice render that sofa its great love the leather material looks real my friend DOF effect amazing the only thing that i will change its the wood floor, but for the rest Amazing Omar, hey man share that leather material ;D
upssss i forget: The lamp also amazing
REally nice some minnor things like the floor and try increasing ths subdivs on the wood of the chairs and the table of the corner
One more thing where did you get the dark wood of those chairs i cant find any good of these style ..also the leather material is verY GOOD can you share the settings and map of it ?
well guys, first of all thank you for your advices.
i'm posting some images to share my advances:
CAMIONERO: wood is Wood_Cherry_Original from sketchup, i just re scaled it and changed it's color.
DAVE AND DWANIMATIONS: leather map is from cgtextures.com. just go to FABRIC and then to LEATHER... i picked the fifth one and used the tiled version of it.
To set it i just imported it as a jpeg texture and set it on a single plane, then selected it while holding alt key and applied it to the sofa. i changed a little it's color because i wanted it to be brown, but in the end i just let it the way it was.
here i post images of how this map looks applied on sketchup, as well as the images of material editor such as bump map and reflection layer with 1.35 for frenel.
have a nice day and thank you again.
los campeones no nacen, se hacen...
hi there Omar,
i really loved your images...
hope you don't mind but seeing that you made a rustic style, i wanted to make a modern version of your image... when i'm done with it, i'll post it in the gallery... i really hope you'll like it ;D
21D: yeah man, no problem, as i said, this is not my style, but i wanted to make the sceene as real as i could... that's why i picked that armchair and those textures, cause i wanted everything to have a material applied. i cant wait to see your work.
DWANIMATIONS: first of all you gotta be sure that you're working with components and not just groups, cause once you apply materials to complex shapes file's size does grow a lot. this simple little sceene is over 220 mb and i did not have to explode anything, but armchair model is the most realistic i could find from evermotion, as well as the lamps and table... this sholuld not happen with normal models.los campeones no nacen, se hacen...
