Dear fellow members
I am having troubles with my glossines and aliasing settings....Here are some test images I did to test the most correct setting but I did not get very far....not as far as I wanded and not as far as vray is capable (I HOPE!!!!!)
On the first two images please one very distracting thing:
Aliasin on the more horizontal edges is very unsatisfactory...the more the edge is horizontal, twe worse it gets....All the materials that have glossy refraction and reflection have these settings:
- Interpolation -3,0 with 50 subdivs and 50 samples....both tresholds at 0.25 ( I think it far enough)
Furtermore I set the aliasing
Simple two level 2,4 or
Adaptive 1,3, which is enough as well....
I have Catmull rom on
Direct computation does not solve the problem, only makes it long to compute....
What shall I do ...I am getting frustrated, cos I can see that vray can do much better than that.....please give me some advice....
Thank you so much
This last is with Direct Comput (the metal) but it has some grain (10 samples)
PS:
Ill be at the hospital (surgery) for two or three days, and I BEG you
to come up with a solution....thanks in advance...
Thank you so much
PS:
