Interior/ Exterior/ Night
  • Interior/ Exterior/ Night
    My new renders in less than 2 hours thanks to the recomendations...
    (my last post took over 50 hous of rendering!)
    Comments are welcome...
    Vray 1.48.83 + photoshop cs4 + sketchup 7.1
    Re: interior/exterior
    those are some nice renders
    i believe your images are a little too burn and that you need some color correctios for the grass...
    keep posting
    los campeones no nacen, se hacen...
      Re: Interior/ Exterior/ Night
      Hello dan nice renders, you are doing great job all you need its to improve your quality.
      here it is the material: And for the separations you have to model that, http://www.megaupload.com/?d=F2F4C9PQ
        Thanks DaveReyes for the material, but it doesn't load, i press "import material"and select the "panels.vismat" and nothing change in the settings.
          bueno te paso los setting aqui mismo, es un material difuso color blanco le agregas una capa de refelccion con un valor de glossisnes reflection .85 y higlight .80 luego le agregas fresnel con un valor de IOR de 2 y importante agregar subdivision 3O en reflection layer y ya estas.
            Muchas gracias por la información, se aprende mucho en foros como este donde hay gente dispuesta a ayudar. Gracias.
