Mirror Rendering problem
  • Mirror Rendering problem
    HI guys,
    I'm facing a problem in mirror rendering. The object which are little far from the mirror are not getting rendered in actual color but shows all in white. While the object near the mirror reflect in actual color. Could you pls help. thnx.
    Rgds,
    Sanjeev
    Re: Mirror Rendering problem
    Hi, I had the same problem with a mirror once, and in my case it was because the objects that where reflected in the mirror where not extruded (I mean the objects where just plans and not volumes) if it is your case just use the push icon and make them an extrude, also make them components. Hope it helps you.
      Thnx Dan, Now its working... Awesome...
